well every body hates them so lets post whioch are good which are bad dicta dont go there i mean this there deadly
shimano ..........
acs one of the best but can still brake ive had mine on for 4 weeks and its just nearly dead
white industries The ENO sealed cartridge freewheel designed for Single Speed and BMX riders is now available! This could be the perfect freewheel for Bike Trial riders too!
Addressing the problems that have plagued Single Speed/BMX users became the focus in developing these new freewheels. Bearing problems, tooth configurations and engagement problems were issues that White Industries concentrated on in developing the ENO.
The freewheel was designed around the sealed cartridge bearing. The bearing is a press fit bearing so when it does wear the rider simply pulls out the old bearing and presses in the new.
Good and save Freewheel engagement is a important point. You need quick engagement that doesn't slip. White Industries ratcheting mechanism has 36 teeth in which four pawls engage. Another leading brand has 20 teeth and two pawls .. you do the math!
The freewheels are availlable in sizes 17t-23t in one tooth increments.
The weight is very low too at only 173 grams for the stainless steel version and 113 grams for the titanium version!
profile hubs ..............
ones with.............. next two please add your info as i have none
so far its all i have any info will be greatly apricitaed
Help
Back to top
MultiQuote
