Syntace Trials Frame
Maximus
Yo!
Found this guys, whilst looking for some new XC stuff.
Link
"Presenting the limited-production Syntace Trials Frame. By using the same refined cold-forging technology and materials know-how we apply to our famous Syntace handlebars and stems, we are able to produce an extremely rigit, lightweight trials frame with unmatched durability. The trials world will never be the same."
"Supertuned Geometry"
Trials riding demands razor-sharp handling balance, which we build into our frame with carefully selected angles and geometry. Our trials frame possesses a one-piece feel that's obvious the moment you take your first bunny-hop. Our tight geometry gives optimal weight distribution for superior climbing traction, precise tracking and quick response - just what you need for clearing obstacles and cleaning sections you've never made before."
"Detailed Engineering"
"Detailed precision is what trials riding is all about, and that's how we build our trials frames. Syntace trials frames are build without the usual vent holes, demanding superior weld precision and affording greater rigidity for optimal power transmission and traction.We forge all our small parts, for superior strength compared with heavier CNC'd components, and treat our frames with a shot-peened, black Eloxal finish which is extremely durable and saves 200 g over conventional paint and powder coats. They're little things, but they add up to a serious advantage."
"Tuneable Downtube"
"The trials frame's downtube features an air valve and pressure gauge for the ultimate in ride-tuning. Adjusting air pressure changes impact feel and response, for that extra edge."
Weight - 2490 inc, fork and uncut steerer tube.
Wheel Base
Short: 1050mm
Long: 1065mm
Head angle
70.5
Fork and Carbon booster
Kg, 0.798 (uncut)
59 grams
Just thought id give it a shout, there you go.
Maximus!
Tuneable Downtube"
:mellow:wtf ?? i dont´t have enought english but,, wtf menns that ! ,,, it´s dosen´t work ,, it´s a bad joke ,,,
This topic is now closed to further replies.
