Grinding Rims
TrialsDisplay.co.uk
Do what I did :-
1. Nick lewis's grinder
2. Take grinder home and take wheel and tire off bike
3. Take inside bathroom
4. Place on the bottom of shower cubicle
5. Get extension lead into bathroom
6. Place one foot on it
7. Grind to f00k
8. Shout rest of day because you deafened yourself because u used a grinder in a tiny little en-suite bathroom at uni accomodation.
9. Stand back and enjoy what you have done with a beer and smile at the fact you just woke all your flatmates up :D
10. Still have lewis's grinder because he got hit by a tram so didnt feel like picking it up.
Tartridge, that rim looks sweet :thumbsup: I only have a small hobby tool grinder which only has about a one inch grinder bit on it! it is good for a light grind but only lasts for about three rides till it wares off. and cos of the small grinder bit, it takes me ages cos only the middle is in contact with the rim at a time. it makes applying tar easier though.
  • 2 weeks later...
A slight grind is amazing with meagmo/monty pads
I did mine with a file and then cleaned the rim with
some muck off ( I am very gay and if my bike is not
clean then I cry)
it is much better than tar and works like a bich on speed in the dry
and ok in the wet(I dont ride in the wet )
any way if u dont want a massive grind in your rim use a file or hack saw
takes about 1 hour but just do when u are watching tv or somthing...
pxdanny :thumbsup:
  • 2 weeks later...
  • 4 weeks later...
I use a metal cutting disc, gives a really rough grind, eats pads!
I hold the grinder at a 45 degree angle, but it doesn't really matter much.
Gray is rim, green is grinder, yellow arrow shows which direction to "drag" the grinder to.
