Tyre Preasures
Guest Trials Punk
Guest Trials Punk
Just thought I'd start a topic on this.
I use 55-60 PSI on rear and 40 PSI on the front. I havn't had one puncture since I run the rear that high with an EL-GATO. Running higher tyre preasures lets u roll faster and dosn't really affect grip in the dry that much but in the wet it's good to use a lower preasure.
Guest endofreak
Rear - 25psi in an El Gato with Maxxis DH tube
Front - also 25psi in a Mythos
I miss My Echo Supa and Panaracer Fire xc :-
Guest Bill
front: very hard 40 psi Fire XC
rear: witha DH Pro about 20-25 with a Dh tube, dunno with my new megablaster though, start at 30 and see what happens hehe.
Guest prawn
depends what tyres basicly, normally i run a front specialised enduro pro 2.2, its amaizng, run it between 35-45 psi, higer if im going really big, on the rear i used to run a megablaster, if ur doing n e thign big u gotta have over 45-50 psi in it or it will pop, now ive got an intense blurr dh, monster thing, im runnin 28 atm, feels so stif, i love it
Guest 20 inch trials
Monty Recommended Tire Pressure (for MOD bikes)
Rider Hard & dry sections Wet & soft sections
Rear PSI Front PSI Rear PSI Front PSI
Ot Pi
Weight: 176 lbs. 25.5 22.7 19.9 17.0
Cesar Canas
Weight: 143 lbs. 22.7 21.3 18.5 17.0
Weight: 110 lbs. 21.3 19.9 15.6 15.6
Weight: 88 lbs. 8.5 11.4 5.7 8.5
Weight: 66 lbs. 8.5 8.5 8.5 8.5
notice these tire pressures are for mod bikes and to me feel way to soft but this is what monty recommend (personal opinion i guess) :ph34r:
Guest Onzaboymark
If you're going to listen to anyone else's tyre pressures, I s'pose you should listen to these people...
Anyway, I loathe/despise soft tyres as much as I hate slack chains. I kinda prefer the more 'agressive' -or 'better' as I call it - feel to my bike, so having what's basically suspension doesn't fit in.
Mark.
EDIT: Just looked up. Son of a...
Edited by Onzaboymark'
Yeah, it seems whenever I go on rides I am the only mod rider who runs big pressures, ie 30 on the back with 40 on the front
Guest EcHoTrOn
hmmm
i have front and rear HOt tyres which to be fair are quite skinny and i use a low pressure cos i like the hoppy feel to my bike, its stif enough so i dony need ard tyres especially the front.
ask prawn how flat i have the front :D
anyway i cant be arsed to use a gauge i use my thumbs :- and use a football pump form giles sports as my track pump nearly took my eye out, gald i dont get that many punctures.
ally
p.s has the toolbar colours etc changed ?
  • 2 weeks later...
Well i used to be a fan of this "Pump them up so they wont pop" attitude, until i tried lower pressures. I always used to like them, but used high pressures for pinch protection. Anywho, i thuogh i'd give it a go, so i bought a hutchinson DH tube to try, in my megablaster, at about 27psi (30 to be sure of getting no pinches :D ). Anywho, i ain't going back now - my bike feels just as i like it, and my riding's improved (especially gaps - maybe unrelated though :wacko: ).
I reckon everyone should at least give this setup a go, even the weight freaks (i went from hot S + latex tube to this setup - adds a fair bit of weight - about a pound, if not more), and if you like it, there's no going back :-
Oh the tube weighs 350g (i weighed it).
I'll second what Tomm says... I added about 500g to my rear tyre recently, and its great.
I used to run an F519 with Hot S and Latex tube... now im onto a 521 with Intense and standard tube... a good 850/900g heavier!! :D
Feels good though, cant complain!
(feck... i never thought it was that much :- )
i run 13-15psi in an elgato with a standard MTB tube..
no punctures in a while, just nice and squishy.
as you may have figured i dont ride street on this. i ride natural and it works a treat..
i did rim out on a 5ft drop though :-"
just shows you how smoooth he really is, tooo dam smooth, along with ben
anyways, the guy with 45, in a dh tube with halo tyre, i did the same, pinched it every ride, i ran it at 30p.s.i much better, as it doesnt blow out the tire
try it honestly
Not really.
You'll probably find a 519 is stronger sideways than a cheese rim. LTC_Dave is running one at the moment, and hes giving it plenty of stick, just like i gave mine :-
  • 2 weeks later...
I’m finding I’m happier with 75 in the back (Luna 2.5 tyre with a standard tube…might need to get a Reluctant thick tube or something), and about 40 in the front. That’s primarily riding street. Might need to let her hiss for a bit before riding on rocks, I suppose.
Mark.
This topic is now closed to further replies.
