max-t
  • Days Won
    2
Everything posted by max-t
  1. Dont buy it, theyr crap...The stocks ae very good but the mod versions ride crap. You would be much better off getting an onza t - pro.
  2. max-t
    Some Pics
    Looks like an MB-GAY to me... Nice pics, that place looks interesting to ride
  3. OH MY GOD... NOOOOO!!!! HORRID
  4. Hog's are crap. Get an Echo rim.
  5. Well thats a rip off then, f**k using alloy bolts. Crappppp.
  6. hahaha, they ride shit..
  7. You cannot annodize steel.Therefore the bolts are not annodized as they wouldn't be aliminium.
  8. hows it hard, no little bits to loose. all you do is unscrew a bolt and everything pulls out then slots back together...You only need to take the axle out then the driveshell pulls out.
  9. Been done before, sorry, looks crap...
  10. hahaha, hit the deck pretty hard didnt you for such a small gap.
  11. Get an angle grinder and skim it lightly across the rim in the same direction. keep doing this till all of the rim is rough.
  12. For a viz rim its 168... so probably around the same size...
  13. More friction = better grip and hold. And also, it does help with water shedding. It wears down ultra soft pads quickly e.g zoo! koxx yellows etc. If your concerned about pad wear then get harder pads. Smooth rims with tar can make the pads 'stick' and this causes loss of power from static moves if they dont come unstuck too well. Also, any slight bit of moisture and a smooth rim will provide a crap holding brake where as a grind will more or less perform the same, given it has good pads working on it.
  14. Please sort 'you' out in your personal message
  15. its a discussion, chill out. Probably more expensive because of the above reasons and because it is very popular over here so people will pay higher for their parts.
  16. awwww... I thought it wa good
