Need Help Bolt Rounded
Lei ke si
Can any want help my hope mono Master cylider cap the 2 small bolt have rounder..need some tip to
take out..
most people use a hacksaw or a dremel and cut a groove in the head so that a flat ended screwdriver can be used. After this however, i would definately replace the bolts with new ones
hope this helps :)
Sometimes cheap allen keys are perfect for this - use the one the next size up and clout it into the rounded hole. The cheap allen keys are generally a bit softer so you'll get the bolt out. I'd say only do it if you can't do the method above though (Y)
