Magura Hs33 Brakes? Do You Grind The Pads?
Callum219
YES!!! Put them on a flat surface and apply as much force as possible pushing directly downwards on the pad. Once it is in around 5 or six different peices grab some Bostik and stick them back together. Its the sticky property from the glue that makes the pads work better on the perfectly smooth metal rim. The next step in the operation is to make your brake system compatable for your freshly ground pads, simply grind the brake hose in the same way you did the pads; don't bother taking it off of the bike, do it against the frame! A few incisions in the top tube never hurt anybody! Now to compleate the process take the angle grinder and, leaving it turned on, put it down your trousers, reach between your legs and puch it against your anus. Ta-dah!!! You have compleated your first rim grind.
  • Like 6
Thats a tad harsh haha :) and btw dont take pics of the internet and put them as your avatar i personally would not like it if someone else used my bike picture as there's, just saying.
  • Like 1
"DUCKING SHITTY ROCKPADS"
  • Like 1
