Koxx Sky 3 Vincent Hermance edition 20"
Dave Sutton
Recently got back into trials with a few friends who used to ride years ago. Picked this up not long ago and I'm over the moon with it. Feels so light at a little under 8kg as I was used to a 11-12kg tank years ago before this. Bb rise took some getting used to at +105 but I've managed to get used to it now.
Spec
Frame and Fork
- Frame: Koxx Sky 3 Vincent Hermance Edition
- Fork: Echo Urban 2013
Wheels
- Front hub: Try-All K2 Front Non-Disc
- Rear hub: Try-All K2 Rear 116mm Non-Disc
- Chain tensioner: Try-All 'H' Snail Cams
- Front rim: Try-All K2 3.2
- Rear rim: Try-All K2 4.7
- Spokes: Triple butted front, double butted rear
- Rim tape: Try-All, White
- Inner tube (front): Kenda
- Inner tube (rear): Kenda
- Front tyre: Try-All Stiky Lite 20 x 2.0"
- Rear tyre: Try-All Stiky Lite 19 x 2.5"
Brakes
- Front brake: Magura HS33, 4-Finger Blade
- Front brake clamps:  Try-All CNC
- Front brake pads:  Coustellier HS33 Pads
- Rear brake: Magura HS33, 4-Finger Blade
- Rear brake clamps:  Try-All CNC
- Rear brake pads:  Coustellier HS33 Pads
Drivetrain
- Cranks: Try-All Expert ISIS, 160mm
- Freewheel:  Try-All 108.9, 18t
- Rear Sprocket: Try-All Alloy Screw-On 12t
- Pedals: Try-All Elite Single Cage
- Bottom bracket: Try-All ISIS
- Bashring: Try-All Symmetrik
Steering
- Headset: Try-All Sky 2
- Stem: Try-All 3D Forged, 150mm x 30°
- Grips: Trialtech foam
- Handlebars: Try-All Carbon Riser
Geometry (confirmed by TartyBikes)
Wheelbase: 1025mm (for both fork options)
Chainstay Length: 362mm
BB Rise: +105mm
Head angle: 72°
Reach (from centre of BB shell to top centre of head tube): 605mm
Weight: 7.86kg (Echo forks) including pedals!
Edited by Dave Sutton
  • Like 4
  • 2 weeks later...
