are standard hub mounted free wheels compatible with freewheel cranks?
DanielClark
It works because when the freewheel is on a hub, the active part that you control with your feet is the outside ring. The inside part attached to the hub is passive - pushed around by the outside part.
When you flip is over, yes the engagement is facing the other way, but the part you control with your feet is the INSIDE part that is attached to the cranks. The outside part is passive - pushed around by the inside part.
Edited by aener
  • Like 5
