My tubeless mod
Target
After twelve years on 24", I wanted to try a new wheel size. To make things more interesting and challenging, I decided to implement an idea I had been thinking about for a long time - going tubeless.
q0dpea4GkzWKEZnMLJGa6Wo6py52IvcNy1CLVAKt
Tubeless setup
Getting punctures and snake bites is a pretty common thing in trials.  I can recall some gaps and drops with sharp edges that I avoided doing because of the risk of a pinch flat.
Meanwhile, a lot of mountain bikers ride tubeless setups with a sealant that repairs any punctures by itself, sounds like magic. There is also a cool thing called tyre inserts that is used in downhill and enduro to protect the rim and the tire when hitting some rocks, and to prevent the tire from ripping off the rim.
Inspired by Ali C videos with tubeless setup on a street trials bike, I've decided to give it a try myself.
Usually, an MTB rim is sealed for tubeless setup with an adhesive tape: Gorilla, Stans, Tyvek, etc. I've made several attempts to use Gorilla tape, watched a lot of manuals, all seemed nice and sealed, but all attempts failed: the air was leaking in different points around the rim cutouts.
After reading mtb forums and especially fat bike forums, I found out that a lot of fat bikers have troubles with adhesive tape for tubeless setups too. Either it didn't work for them just after installing, or the setup failed after some period of time.
Fatbike rims are very similar to trials rims: wide, single-layered, large cutouts for saving weight. It looks like adhesive tape doesn't stick well to them because of the cutouts: sealant and air sooner or later find their way between the tape and the rim, the leakage starts, and it doesn't seal by the sealant afterwards and only gets worse.
It turned out there is only one reliable way to seal a non-tubeless ready rim with cutouts: so-called "ghetto tubeless" when a tube is cut around and stretched over the rim, so that all the rim cutouts are sealed, and then the excess material is cut after the tire sits in place. Also, there is a modern variation of this method - a latex strip and a tubeless valve are used instead of a cut tube (the "Fatty Stripper" solution).
So, in order to seal the rim, I've used a TPE (similar to latex) strip about 0.5 mm thick on top of normal rim tape, and it worked perfectly: the setup sealed instantly. As for the valves, I've used some Presta valves cut from old Schwalbe tubes.
There’s one really cool thing that became popular in recent years in the mountain biking world: tyre inserts. It gives a lot of benefits with practically no drawbacks:
- Protects the tyre so the rim cannot cut through the tyre when the wheel hits some sharp edge
- Protects the rim from impacts
- Prevents the tire to be blown off from the rim
- Makes pumping a tubeless tyre and sitting it to the bead much easier even with a small pump
The only disadvantages I can think of are:
- Additional weight
- Inserts may be difficult to install
As one can imagine, there are not so many tyre inserts available for wide 20" rims. So I've used a DIY solution that seems to be popular, more or less reliable and customizable for any rim size - backer rods. It's a cord made of closed cell polyethylene foam. It feels dense, much more dense than a pipe insulation or a yoga mat, but less dense than some heavy duty tyre inserts like Cushcore.
A nice thing about tubeless is that punctures are fixed with the sealant from the tire, so you have nothing to worry about and might not even notice that you had a puncture. I've used around 60 ml of Stans sealant for each wheel.
The weight of my tubeless setup is basically the same as with the tubes. For example, for the front wheel: the latex strip is 25 g, the tyre insert is 30, a valve is 7, and a reasonable amount of sealant could vary from 30 to 80 g. That sums up to 90-140 g for tubeless setup, while 20" tubes weigh 100-150 g.
The only advantage of the tubeless setup for trials supposed to be forgetting about snake bites. So I'm going to test it properly on different kinds of obstacles and see if it really works.
Some photos of the process
A rim with a normal rim tape that is necessary to protect the latex strip
4XjOFmZEi6nXNbl6qYtBcQ_QdG8_BpraW72NPhjY
Heat bonding the TPE strip edges
goQ-Gtd8STC1i_dk03WWTLjdDfqdUW-AUuHuYNEK
Stretching TPE strip over the rim, making a nice sealed surface
tsHxlyDXGULiO-s-29-mFSKt2Zu8CCOSNU9bQErA
Tire insert is made of a backer rod cut in half. This is how it supposed to seat over the rim to hold tyre beads and to prevent tyre/rim damaging
9JzEZ0ZBmHwXbtKbSCKi9WcqmslC8iakBFnHDNQk
One bead of the tyre is installed, it's time to install the insert. The insert diameter is smaller than the wheel diameter, so that the insert sits tight and holds the tire.
R2e1irWblCQiHvcZQOJWI9V0TkghzdlmU9Zrzyrf
Second bead is installed. It's better to use some soapy water when doing this.
iI3ro2Q3Krtnl_zub2NIwvn8uM9SP7GI59l29z3B
Adding some sealant through the valve
-RPjuezBeoFoabS8r6aVt7qoCq9Ws3aBY1cc7abR
Pumping the wheel. Sealant starts to seal the leaks.
DPw18HDrZyswiWyFu9cV2Sm2rtjzZJXg45RSPEL-
After some period of time, all the leaks are sealed. Now it's time to cut the excess strip.
SVEIQ6UOc-5OQrMqPL-rJ35QDKn6U5GRSlwA0cII
Bike
The idea was to get a functional and lightweight 20" bike for cheap, in order to try this wheel size. Also, I wanted to be able to get a truly top-spec mod in the future by changing a few components in case I stuck to 20" size. That's why here you can see a weird combination of a heavily used frame with a rewelded disc mount, chainstays grinded because of failed sidehops, and lots of dents, cheap heavy spokes, used alu fork, and in the meantime expensive handlebar, brakes, and a front hub.
M_6xANIT7MPA3snZA2D7s-wj1AmhstXCbVcSj5tx
rOddbahy4kz5z1hgoNvLoede7n2n8oOsMSiplp1a
4eHff9qImuIATMDFLVUwzt2KReuAguC4-uJ8Pk02
w8-PwWPdzwClspCKyvqdOCmeYVJRgeT0IaFFhxui
HMMJG4_kB32y3rj9W8J4ZrKJXElTIM-Rr4kQH_Z0
Fl54ZGS244VYITvqF9KNCydZ0kT3WG6vexrk0Pqt
trjuYBUumxScR5Fe97RJXyRwXZazQzCbEwr3OpaH
pil9gyTV6PLhufzv5oQKAggoo9ufdWo-BKrbNfMJ
Spec
Frame and fork
- Frame: Born Sun, painted black, bashguard mount removed
- Fork: Echo SL
Front wheel
- Rim: Hashtagg
- Tyre: Jitsie Reverz
- Hub: Jitsie Race Disc
- Spokes: Sapim Leader
- Nipples: Sapim 14 mm alu
Rear wheel
- Rim: Hashtagg
- Tyre: Clean Koala
- Hub: Echo SL 116
Brakes
- Brakes: Hope Trial Zone
- Pads: Jitsie
- Rotors: Hope V2 160 mm
Drivetrain
- Cranks: Echo TR
- Freewheel: Jitsie 108.9
- Bashring: Trialtech Sport Lite
- Chain: KMC X9-73
- Rear Sprocket: Echo splined steel 12T
- Pedals: Trialtech Jack Carthy
- Bottom bracket: Trialtech Sport Lite
- BB bolts: Ti M15
Steering
- Stem: WAW Ultimate 155 mm, painted black, re-anodized bar clamp and top cap, ti bolts
- Grips: Pro bar tape
- Handlebar: Clean Carbon K1.2 690 mm
- Headset: Born
Weight: 7.26 kg
Geometry:
Wheelbase: 1008 mm
Chainstay length: 350 mm
BB rise: 85 mm
Edited by Target
  • Like 6
  • 6 months later...
I guess it's time for a little update.
The tubeless experiment went surprisingly well! I didn't have any issues at all with the tubeless setup. No burping, no suddenly lost pressure, no snake bites. I've broken 2 frames and a fork since December, so I guess you can't say that I was too careful with the bike.
I wasn't happy about presta valves cut from the tubes. It was tricky to install them properly on the rim. They area between the valve and the rim was the weakest place in the setup, and tended to leak air if the valve installed not ideally and its nut not tighten up really hard.
So I bought and installed tubeless aluminium schrader valves. They hold in the rim valve hole much better, and the setup feels really reliable now. They needed some modification though since they originally designed for using with high double-wall rims. Some rubber and plastic washers have made it work on the single wall rim.
fGmd-YTEv42AmyEhpI9ATyqrCQM62d5zIlRmxwIt
  • Like 5
