Hs33 crossover and splitter
Jamie1234429292
Wouldn't really make any difference whatsoever, if anything performance would be slightly worse.
The split lines would be pushing the pistons in and the crossover would just hold fluid.
You could potentially split the hose and then split each line again to run feeds into both holes in the slaves but I can't imagine it would improve the feel.
Either way it would be almost impossible to bleed the system.
  • Like 1
