Pedals Giving Way Problem
*PHIL*
Recently my bike has been un-ridable due to the fact that at random times while riding the pedals suddenly give way and slip round.
If you're standing up, you're gonna fall off... If you're on a road, you're gonna get hit by a bus.
Anyone know what the problem is? People have told me the chain is too slack or its an alignment problem.
The bike shop count fix it the first time so I sent it back again but I'm unsure if they know whats wrong. Just wondering if anyone has has the same or similar problems?
I mean its like they're in the lowest gear suddenly and the slip round a lot faster than your feet are moving, so the foot you have all your weight on suddenly has nothing to rest on and hits the ground.
I'm not sure how to explain better than that so hope it helps.
Its like the chain jumps over a few notches on the cog... But that sort of answers my own question. But I'd still like to know what others think
sounds to me like its slippin as you've said
take it you have gears on your stock, mabye try single speed then
it could be that you just need your gears set-up again, ask your bike shop to do that and see if it sorts it
all i can think off, mabye someone else will know more
Dunno about the hub but its an unmodified specialized hardrock.
The bike guy said he was doing something in that area so maybe thats it.
Thanks for the help
Last hardrock i saw had a shimano rear hub (N)
I would say that theres a 95% chance its your hub skipping. And that you should invest in something more reliable like a hope, atomlab, halo, king or profile.
