Rear Vee Set-up
Matthew_Gibson
I'm going to get my stock back up and running and put a vee brake on the back. I have the adaptors. I need the brake arms, and pads. I just want to know whats the best options when it come to these. I can "borrow" a rear of a matey at work. Its an Avid SD5. I'll use this untill i can get a better one, or will this be okay? Also pads - The rim will be either unground, or I will put a LIGHT grind on it. Which pads? Plazmatics V-flys, rock pads, Heatsinks?? Anyother pads worth giving a shot with a grind??
Thanks!
coust pads in cnc vee backings and a light grind
sd5's should be fine.. just a bit more spongy than sd7's or ultimates
but deffinitely get a sd7 lever, you then have the red dial so that you can adjust the stiffness/spongyness/power
get some decent cable on there too, linear slik cable is good
Edited by willy wonka
