Spoke Length/calculator Help
Tom_
Hi,
I just ordered a pro 2 and rhyno lite (24") rim from work, it should be here on tuesday-ish now I can build a wheel but of course first I will need to know the spoke length I need to do this I was going to use the DT swiss spoke calculator. Thing is Iv encountered a few problems...
Basically I have no idea of the measurments that I need, the rim is already on there although there is a measurment it hasnt given..
My question is could some kind knowledgable person tell me what it all stands for, also does anyone know the measurments I will need for a pro 2 trials?
Its quite a long shot but I would like to order spokes on monday for it (again probably through work, trade price for the win) that way I can have it built by mid-week and hopefully ride by about thursday-ish.
cheers, O and heres the calculator... HERE
I dont have the hub or rim on me, the rim measurments are in there I was just hoping somone could just plug me the numbers for the pro 2
Go HERE and click on the spoke calculator. It will give you the dimensions for your hub, and if you can tell it the ERD (effective rim diameter) of your rim, then it'll work out spoke lengths too.
Edit - ERD for those rims is apparently 493.
So for 32h, 3x cross:
Drive Side = 236.9
Non-drive side = 237.8
Please double check that using the calculator I linked to. Also if there's different number of spokes or you're planning to build it different to 3x, you'll have to do it yourself ;)
