Brake Booster
Milford Cubicle
Just got a czar brake booster and tryed to put it on the front of my bike and its to wide :@ is this because i have old forks or because im trying to put it on wrong? Any help appreciated :)
billxxx
did you not measure the spacing between the mounts? i think most booster nowadays are designed for the back brake use, so its standard 100mm wide (centre of hole to centre of hole), i doubt the front would be 100mm......as most front rims are a lot narrower.
steve
steve
No just read the thing on tarty, can you get boosters which fit the front?
billxxx
