Echo Hub, And Zona Zip Frame.
Lewis-Trials
Hello, i bought this echo wheel and Echo hub all together as one whole build, And i got home took my old wheel of and tryed to put this wheel in and this axle on the echo hub is much bigger than the t-master hub, So when i get it in it gets stuck now and then, But i got some chain tensioners that fitted my old wheel t-master hub so the axle is smaller, But i now need tensioners to fit the Echo size axel, Because the ones i got doesnt, Only 1 side fits then the other side doesnt because it got a bit bigger bit on the otherside, So do i file it down, Or is there any tensioners that i can use to fit the axle size and my frame.
Cheers lewis :ermm:
Edited by Lewis-Trials
