Truhative Gigapipe Bb
Adrian
Whats the shell width of the frame, you can measure it it’ll be 68mm or 73mm. Measure the frame across where the BB goes.
If it's 68mm the hard metal washer goes on the drive side and the bendy ring goes on the non drive side. If it's 73mm then you don’t put either on, and the non drive side cup will not sit flush to the frame (few mm out)
It says all this in the instructions.
Edited by 16 years later
