Cracked T-Mag Frame
Warbs
I have an old 2003 T-mag frame which has now got a hairline crack where the down tube meets the headstock.
Is it worth getting it welded or am I better off getting another frame??
Would I find a more moden frame say a t-pro, Blade etc alot easier to ride, I am fairly new to trials and have never ridden any other trials bikes???
Tom
If its a small hairline crack you could always drill a VERY small hole to help prevent the crack from spreading any further.
Failing that, if its only a small amount of area that needs welding you could get that done, but I wouldn't ride it for too long welded as the welding will make the material more brittle.
