Magura Hs33 Problem
TrialZonn
Hello everyone.
I'm using a magura hs33 brake at the back 2005 model with standard lever.I was riding my bike,everything was fine and the brake was working amazingly.Then suddenly (when I pushed the lever another time) the lever got all the way in the body and it touched my grip.I didn't understand the reason:no leaks and I re-bleed the brake after that and it keeps getting all the way in!My pads haven't moved from their positions on the clamps.I unbolted the lever and didn't see any leaks or cracks inside the body neither.
Maybe the piston has the problem?
What should I do?
