Internal Headset Help
Sam T
Your problem isn't very clear so its hard to help. The Gu takes a standard headset and the monty uses an internal? If thats the case then you will need to buy a new headset as the 2 aren't compatible. If you just want to know how to switch the headset then my advice would be to take it to a bike shop or local halfords. It's easy to damage it if you don't use the right tools and are unexperienced
