Crank Arm Problem
D Rock 45
After buying a new frame onza blade, an putting my old onza pro bottom braket an crank arms on it . the left crank arm is rubbing on my frame when i ride. an theres alot of space on the freewheel side . I checked it an theres no play in both the left an right crank arm an blots are tight an dont come loose. The same with the bottom braket its all fine an running smooth .
Is theres any way i can space it out, or will i have to buy new parts ?
If theres any advice you can give me it will be much appreciated as i will be able to ride again one fixed :)
Thanks
Which bottom bracket cup did you fit first? I have accidentally fitted the left hand/non drive side first and pushed it a lot further in the bb shell than what it be, so as a result the actual bb can't be threaded all the way into the bb.
Failing that it might have to be a marginally longer bottom bracket.
