Try-All Hub 4Mm Wide Gap For Fork Wth?
neilrobson1989
Don't really understand - Could you take a pic / use paint to give us an idea? Only issue liek this I've had is the bearing coming out slightly on Rockman BUB hubs, meaning you can't get the fork in. If you can see the shiny silver ring of the bearing protruding from the hub shell it will need pressing back in.
On your hub both sides are (supposed) to be freely moving so you undo bolts, slide in fork, tighten up each side.
