Speedrace Fans Stock
Jon Alty
So picked myself up an Echo Pure build and a Speedrace fans frame as I've allways liked the look. Just got it built up and headed out for a quick ride today! Needs riser bars at the minimum at the moment, maybe a different stem.
Spec:
Frame: Speedrace Fans
Forks: Echo urban disc only
Headset: Echo SL gold
Front wheel: Hope Pro 2 on Try-all gold rim
Rear wheel: Hope Pro 2 on Try-all gold rim
Front tyre: Maxxis High Roller
Rear tyre: Maxxis High Roller
Bottom bracket: Reset
Cranks: Trialtech.
Pedals: Trialtech Magnesium
Chain: Kmc Kool.
Bars: Adamant Flatbard
Stem: Answer (cheapo stem) - have a hope cnc but is too short really
Grips: TrialTech with lock ons
Front Brake - Hope Mono Mini
Rear Brake - HS33 (far too long cable), GU booster
what bars did you buy?
what sprocket are you running at the moment? if its a 14T want to swap? i've got a 15T.
Some try-all Rage Bars off charliemod. Yeah I am running 14T ATM, don't have a cassette tool ATM though so can't get it off until tarty/lbs stocks one.
