Loose Rotor Bolt?
holroyd-wanna-be
Afternoon, all last week my disc kept making a chinging noise when i tapped the bars so i took the brake off and checked it over. I noticed one of my rotor bolts was loose and would not tighten up :lol: . This is the first time i tok the bolt out and now it just wont tighten properly and all the bolts had thread lock on. I have thought about using Araldite on the bolt but have i got a chance of getting the bolt out if i use it? B)
Soory to waffle.
Lester :P
i had this problem with a crank bolt and what had happened is the loktite has bunged up the hole or its cross threaded. as i say loctite bunged up the hole on my bb and the crank bolt wouldnt tighten. try using some de-greaser on a loth and a screw driver to scratch the loctite out of the bottom of the hole. :lol:
