Creaking Bottom Bracket
yoyoyo
At the mo i have a creaking bottom bracket and was just wondering if anyone knows how long it will last before it goes or just not to ride till i get a new one.It's just a shimano one(not sure which) if it helps
Cheers,Joe
Just grease it, take your pedal's off, crank's and bb out, then clean them all, tighten the chainring bolt's, make sure the pedal axle's are tight, if they are caged pedal's then make sure they are tight , clean the lot of nice and good, grease the thread's on the bb and put it in nice and tight, grease the crank bolt's and put them on, then grease the pedal thread's and put them on, sorted, if it still creak's then go mental, shout lot's and throw stuff, then buy another bottom bracket.
I had this problem with my old fsa platinum pro bb.
There isn't anything much you can do but replace the bearings or buy a new bb (probably cheaper). Check that everything is tight and greased up and just ride it, creaking may be slightly annoying but its still rideable.
if your using middleburns make sure the lockring that holds the bashguard on is nice and tight, ive had this come loose and make it sound as thought the bottom bracket was creaking.
Edited by Ingram
Cough Cough... NO. Right this is wear people make the mistake of thinking grease grease and more grease. Grease doesnt solve everything you know.
Right...
Use a Crank Extractor and Bottom Bracket Tool to remove the Cranks and Bottom Bracket from the frame.
Thoroughly clean and degrease the Bottom Bracket Shell and Cup Threads.
Wrap the Cup Threads with PTFE Tape. (Start From Inside and Out lol)
Put a Small Coating of Grease on the Bottom Bracket Shell and Threads and then Re-Install the Bottom Bracket and the Cranks.
Chears Dudes.
P.s. Just remember to check regulaly and regrease when needed.
Edited by Koxx_TryAll
