Quick Bb Question
Alex-Mitchinson
I have an onza t-pro with an oversized BB shell.
The width is 73mm.
Will a truvativ gigapipe fit? On tarty it says it will fit 73mm if you take the spacers off, does this include oversized frames?
It is the only BB i have found with a 73mm width and at least a 124.5 axle.
Urgently need to know......
Cheers.
The only BB you can run in that frame is the Onza Square Taper model in 119mm axle, its the only BB available with oversized threads on the cups.
If you need a longer axle you could buy a 119mm and a 127.5mm and swap the axles though (Y)
Yeh I have already done that but cheers anyway,
Just that I'm fed up using crap sqr taper BB's.
Thanks for the replies.
