Profile Hub Help
DEZ
hay when i tighten up my profile to the frame the wheel gets tight and does not free whel easy (N) it sounds like somthing is rubbing/ grinding inside :huh:
i can not pull off the casstte to look inside i tried a tip from tarty and taped the axel out from the other side not its not releasing the whole castte itself any ideals
help bits
- i cross threded the axel :$ all be fixed
- have pulled our th axel
thanks Dez
Edited by DEZ
its either bearings or incorrect washer placement
have you moved any of the washers/spacers around since last tightening? if not, check the driver: take the wheel out the frame and pull the driver out and pop it over your finger. turn the cog around and feel if theres any rough spots. If there is then you have the oh so fun task of replacing the driver bearings. If its not the driver bearings, pick up the wheel without the driver in and give it a spin. If it feels rough in your hands then its the axle bearings which arent too bad to change
enjoy
