My Psp = Help Please!
Trials Boy
Hi,
Got my PSP this morning and its fine working and everything, but then i connect the USB link cable to it and try and send some music files to it, on the Computer it says there on the PSP, i looked on the PSP it says 'No Music Files' :D
Does anyone know if i'm doing anything wrong? B)
(Same with photos and videos)
Cheers :shifty:
Edited by Trials Boy
I'd just like to say, i know EXACTLY what you're doing wrong.
First things first, you need to go onto your psp and through options choose 'format memory stick' this will setup the stick for use through the psp. It makes individual folders for music, pictures and savegames. You can then use the usb mode to put your music (must be mp3) and pictures (must be jpeg) into these folders.
Now as for videos follow this tutorial http://www.pspcrazy.com/3gpguide.html
Hope i helped.
Hope i helped.
I just did that for the Music Files and it doesnt seen to do anything (Y)
Chicky already gave you all you need to know, however his tutorial isn't the best one around.
1st step: FORMAT YOUR MEM STICK using the options in the psp's menu.
now, connect the psp to you computer using the USB cable, and open it as a removable storage device. You should see 4 folders:
GAME
MUSIC
PHOTOS
SOMETHING ELSE (i forgot this one)
anyway...
TO PLAY MUSIC:
COPY YOUR MP3 FILES INTO THE 'MUSIC' FOLDER.
NOTE: The psp can only play either mp3 files or sony specific files. If you copy wmv files or itunes files over, they will take up memory, but you will not be able to see or listen to them.
once you have copied all the mp3 files you want, press cancel on the psp, and then disconnect the USB cable. Then once you scroll to Music, you should see a long list of all the songs you just copied over. :-
TO PLAY VIDEOS:
Open the psp folder again, like a removable storage device. Now, you have to make a new folder called 'MP_ROOT'
so then you should have 5 folders:
GAME
MUSIC
SOMETHING ELSE
MP_ROOT
Now, open the folder MP_ROOT and make another new folder called 100MNV01 THIS IS WHERE YOU WILL COPY YOUR MP4 FILES TO.
NOTE:
PSP CAN ONLY PLAY MP4 FILES. If you wish to play something such as a trials video, you must first convert them into MP4 files using an MP4 convertor.
(i have two if you want me to recommend them).
Once you have converted the files to MP4 they will appear as two files for example:
M4V00001
M4V00001.THM
you MUST copy both these files into the 100MNV01 folder for the PSP to play them, and you MUST NOT rename them.
Leave them as (for example) M4V00001, they will appear on the psp as whatever the initial file was called. e.g Trials_vid1.wmv
I still have a ton of family guy episodes, southpark episodes, BMX videos and Trials Videos in MP4 format which i converted to play on my psp. (which i have now sold). Which i can hapily send you somehow. :D
If you get stuck (i'm sure you will cos it's kinda tricky) let us know. (Y)
GAME
MUSIC
PHOTOS
anyway...
TO PLAY MUSIC:
TO PLAY VIDEOS:
GAME
MUSIC
SOMETHING ELSE
MP_ROOT
NOTE:
M4V00001
M4V00001.THM
Can you send me any song on the 'Proper MP3' File please mate?
That really helped :P
