Magura 2004 Leaver, Piston Stuck
trial-biker-ryan
I had to take mine all apart, and where the hose comes out push a spoke up inside to push the piston back out. And now I am very weary while bleeding the brake- if both bolts at the ends of the system are closed it's fine for the lever to be compressed and will return, but while bleeding I don't compress the lever fully! Hope that helps
