Maya Help
Nick Garland
Right I am modeling a bike for my computing course, it needs to end up being rendered in 3d etc, however I first need to make the model useable.
How do I modify the polyons so that they merge properly and do not protrude?
How do I texture them?
How do I cut holes in them, such as the BB, or general manipulation of the polygons?
Here is what I have done, its not fab but it will be good enough.
Also if anyone knows of any good tutorial sites that would be good, I have found a few but none seem to be of much help with hard to follow tuts.
Cheers, Nick
don't bother at the tube junctions. with the forks you're better off extruding a circle along a curve than building it from cylinders
quickly and simply?
select a tube
set main menu to Polygons
go to Create UVs menu
Select Cylindrical Mapping - this'll allow you to wrap a image file around the cylinder.
Do that for all the tubes.
to apply an image to the tube
Make the image you want in photoshop
select the object,
get the attribute editor open,
find the Material (lambertsomething),
click the little chequered button next to color,
choose file from the dialog that pops up
browse for the file
make sure you turn on hardware texturing in the viewport or you wont see it. if the image is in the wrong place then mess with the cylindrical mapping gizmo
There are better ways but I'm guessing you won't have the foggiest idea what I'm talking about
to do the BB shell
make a smaller cylinder thats the size of the hole you want and run it through the middle of the BB shell
select the BB shell
Shift select the smaller cylinder
go to the mesh menu
choose Booleans
choose difference
it'll cut you a hole
you could do that for the tube junctions too but theres not much point
also, you could just have made a tube rather than a cylinder
General Polygon manipulation ...
select the object
right click
choose vertex from the stupid messy menu at the top
select the little dots and move then - you can also do that with faces, edges etc.
There's a bunch of tools in the Mesh and Edit mesh menus that you can piss about with too.
tutorials?
they'll be hard, Maya is complicated and a turd to use. start at Highend3d.com
or if you're on a legit version of Maya you should have access to the Maya online docs - which are good
edit:
oo, looks like you're on 2008 - I'm on 8.5 at the moment, we aren't moving up to 2008 till later in the year. Some of the menus might have moved n stuff but I doubt much has changed
Edited by poopipe
I am indeed on 2008, thanks to uni get it free :P Well ish, whilst I am here anyway were allowed to run it off the network.
Thanks for the help, I could not work out for the life of me how to texture things, I just need simple textures.
Next question, with XNA you need to have the model and the textures as seperate files, the way I am doing it anyway. How can I export the model as .fbx and have the textuers as .tga???
Update: Quick update of the model, its not fab but heh I have been using this program since last night.
Edited by Team War Rider
that'll just happen - unless you choose the embed texture option on the FBX export dialog it'll just reference the .tga files from wherever they live on Disk.
To make life easier for yourself, put the textures in the same folder as the geometry, it'll save you pissing around later.
i get 2008 free with the developer licenses at work they just won't let me use it for anything yet (I've got a full licensed 2008 box under my monitor that nobody knows about though .. :shifty: )
I'd take it home but I hate Maya (edit: that's a bit harsh, I've just been arguing with it for the last straight week)
Edited by poopipe
Max is king. I'm biased cos I've been using it since v1 and was using 3dstudio for DOS for a couple of years before that but it's still got the most comprehensive set of polygon modelling tools available.
Lightwave and Softimage really piss me off but they're very good - I believe there's a free version of Softimage available (there was)
Free ones?
Blender is about the only one that's capable of producing finished movies but it's beyond nasty to use and because it's open source it doesn't work properly (fbx export in particular)
Wings 3d is a very nice modeller but the last version I unused was a bit limited apart from that.
What you use these days is pretty irrelevant since Autodesk started taking FBX seriously. Transferring stuff between Max and Maya is pretty well seamless (barring a few idiosyncrasies) and as far as I know Soft and lightwave have acceptable FBX support available.
