Brake Gripping Techniques
whats the best way to make my brakes grip the rim better i have ordered some brake boosters to stop the fram flexing as much but i have seen some websites saying grinding your rims is best other sites say taring them is best any better ways to make them grip better ?
thx!
Grind you will get good performance in wet and dry and the brakes wil work and hold alot better also a dab of tar can help becasue it is sticky but not to much other wise you pads will stick to the rim when you pull it (Y)
Grind are cool, but boosters and good pads are important as well.
I used tar, it was ok, but really temperamental, too much and it stuck on, too little and it didn't work etc.
You best bet is just to grind in my opinion. But it needs posh pads as well to work well.
I got bored of faffing about and just got a rear disc.
Best upgrade is some new pads.
Have a look on tartybikes.co.uk for all you cou;d ever want.
Search for pad reviews and you'll find the one that fits your budget.
Then you can go about tarring/grinding.
Yeh tarty or trials-uk dp loads of different pads for different set-ups.
