Sponge
.. I used an Echo bashring.
and I'll be using that little spacer ring in future, as I have a bashplate.
I don't believe the problem lay there. I am guessing it was poor manufacturing or tolerances. Just a dodgy thread from a bad batch I hope.
Don't, I chucked the spacer and ground the crank arm down almost upto the thread so the freewheel hit the crank arm, thus using all of the available thread.
I Havent/didnt have a problem with the Echo cranks that I had, I was running a free wheel on the front with a bash then no bash, All I done was to cut the bash down, so It acted like a spacer.
Can you not get in touch with Panpa and say that you got the x months ago, and justr came back from injury. Maybe they wil be sympathetic.....
