Mod Chain
Zoo_Python
Buy snail cams with notches in? Or fill notches into your ones atm.
Or if you mean once its all set up, the cams can easily move out of place - this is because your cam is to thin for the spacing on your hub, and thus it can't clamp to the frame. (I had this problem with my Try-all cams, so I made a little spacer from alu sheet. Works fine now :))
Hope I've helped (Y)
You might have a lot of power in ur legs and be stretchin the chain loads? I did this when i first started ridin and now im running the new shadow conspiracy half link and its ace? try that! :D
We.
Do you know where i could get me one of them as miht help me alot
