Help With My Maguras Please
robo
Squeeking is good. :)
I presume you mean when you pull the brake ?
Squeaking usually means there is vibrations , which is usually due to flex in the frame. This is why it makes the noise
The noise is good to a certain extent, to remove the noise you need to reduce the flex that there is around where the brake is. This is usually done by getting a booster.
AS therefore the frame is stiffer , and less vibrations are created and less noise
Hope this helps :D
Hope this helps :D
This only happenes with my front brake not my back.
