Lowering My Stem
markrat
Take the stacks out from under tha stem, and put them above the stem then try it out.
Just play about with them until you find where you want it, then cut it down.
To cut it down, wrap tape around it and use it as a guide, then cut it down and file it down.
You could use a grinder aswell, I find thats the best way to get it accurate.
Ok. I`ll have to find the length and offset of my forks. There gusset jury`s i think.
Just had a look and internet reckons my forks are 403mm and have a 1.5" rake. Does that sound right. Also it says they are 1600g, that seems heavy to me.lol
Edited by markrat
gusset jury's are heavy forks...mainly intended for street or dj
You could save nigh on 800g if you go for some echo urbans
