Eno Freewheel Problems Again !
Andrew Willis
Hi lads, tried to get the freewheel off the cranks today and it wont budge, the bike shops have tried it aswell and they say it wont budge so it looks like im going to have get a new outer shell.
The egadmentments in the outer shell are fooked well, 2 of them are so i need a new outer shell. how do i get the bearings out of the current outer shell that i have on.
Also some of the pawls are chipped, could this be the reason that my outershell has cracked?
All advice and opinions are well appreciated.
Thanks
Andy(Y)
Hmm, probably not, but it does sound like it could do with an overhaul.
If the tabs aren't too mashed, feel free to send the crank arm to us and we'll whip it off for you (only charge will be postage back to you). We've not failed to get one off yet :)
Cheers
Ads
Thanks
Andy(Y)
Thats brilliant adam, thanks, we will arrange for it to be sent tomorrow, ill leave the lockring off so all you need to do is pull the outersheel off and you can have a look at it.
if you do get the freewheel itself off, could you replace it with a tensile and bill me?
OR
While its there, just replace the outer shell.
Your help is much appreciated:)
Cheers
Get the outer shell apart fro mthe rest of it
Get something (small screwdriver for example) to prise the black C-clip away from the bearing, should pop out with a bit of a fiddle.
Push the bearing out.
Done.
Done.
haha! Sorry for my immaturity lol! But that really made me laugh!
Your useful?
Send it to Ad, He should help. And put a little postit note in there saying to record a video. It would make great comedy :P
Thanks for all your help lads(Y) much appreciated.
Sent it off to tarty today if they can get it off a tensile is going on but if they cant then itl have to be rebuilt:)
either way, things should be ok with it.
Thanks again to you all including Adam and tarty bikes
Andy (Y)
