Crank Pedal Thread And Bb Bearing
gage-mann
hello everybody, i got a right-hand echo crank thats got the pedal threads stripped and i'm unsure of how to fix it? was think of buying a tensile crank insert but only left side crank one's are in stock on tarty although if i managed to tap the crank for the insert and then taped the inside thread of the insert for the right side pedal would that work? and anyone know where you can get hold of the echo external bottom braket bearings on the old bearing case it say ezo 680SRS i need one as i broke one while trying to get it out >_<
cheer's
