Mad Phase 1.2
MadNick1.2
Hi all,
Does anyone know if the rear disc mount on a mad phase 1.2 is international standard and also if i bought a hope mono trials disc brake for it would i need an adaptor to fit it.
Plus what size rotor would be best to fit this set up.
I ask because my newly ground rim is eating brake pads and i think long term getting a second hand mono would be better.
My rear wheel has a hope pro 2 hub, with 6 bolt for disc.
Thanks in advance
Nick
Edited by MadNick1.2
Hi all,
Thanks in advance
Nick
What pads have you been running?
I also have another problem when setting up my maggies which is pushing me towards disc.
I cannot get them to sit square against the rim, think this is because i have a very wide rim.
I have already fitted the tensile offset adaptors which enable me to fit the pads but as i say they wont sit square against the rim and at the moment on a slight angle.
Unless you're incredibly smooth I wouldn't bother with rear disc, the only rider I know who can stand the flex is Tarty Adam, and he's incredibly smooth.
Just get some harder pads or wait for the grind to go blunt!
I was going to get some fhat pads but they have to be set up perfectly square to the rim which i cannot achieve.
What other pads would be an alternative.
I have just put some Rockman pads on, the blue one.
Hopefully these will be an improvement when i go ridin tonight in Tamworth.
