Few Questions.
Mikey Tomo
Reeto, got a few questions abot the Echo TR rim brakes.
Do they leak at all? Apparently yes.
Do they leak when water bled? YES!
Are they any better than maguras? Why? No, for the above reasons and very little if no extra power.
Thanks in advance, Mikey x
It would take a bit of work but if you really wanted one you could get it to work fine.
You'd need to take it apart, clear it out fully, lube it all up with silicon spray and change the O-ring in the piston. Then that would be fine to bleed it with water. It's a lot of faffing around but I'm pretty sure doing all that would work fine.
