Tighten Mod Echo Rear Hub?
DannyBazz (:
Right, Just had everything out of my Echo hub, it wasn't running too smooth and was slightly loose. I put it all back together, exactly the same as it was, but the axle is really loose. I've tried hammering the bearing in further, tightening the wheel... No luck. I understand the hubs are pretty poo, I've had one before and that came loose too, but sold it on.
Any help on what to do would be appreciated.
This hub: http://www.selectbikes.com/index.php?act=viewProd&productId=204
sounds like your bearins have collapsed and hammering em probably aint done them any good, if its not that then f**knows
Nope bearings are sound, I thought of that, so took em out and checked em, nothing wrong. Axles not wobbling up and down, its like side to side if you get me
right just a thought maybe your bolts are locking out on your axle before they'r getting a chance to tighten on your frame ??, if its that then you can just whack some spacers in there
