Magura Help.
Tom Canham
I have a rear Hs33 and it has been working fine until recently.
It has started to rub to the rim every now and then.
I have noticed that when you let go of the brake the brake pad does not move all the way back to the original position and is rubbing on the wheel.
It is only on one of the sides.
Any help would be good.
Thanks
Tom
maybe a lazy piston. how did u get it working?
I just adjusted the tpa and re aligned the pads and they seem to be working...
but now the brake cylinders move within the mounts and there tightened up.. I dunno whats wrong now...
Did you check if the pad was sticking to rim because it was covered in tar?
there was no tar on the pad from what i saw, i think that it was just a tpa problem.. but they move.. and the mount bolts are quite tight.
