Disk Brake Fluid
Nathan Cox (woodman)
you can bleed them with water and they feel nice with water just in the winter you will probally want to mix in some antifreeze or summin like that
Never put water in a disk brake, when the rotor / caliper heats up it'll boil the water and you'll end up with an air filled brake.
some one told me not to put water in them because it corrodes the seels
Bollocks, I guess "someone" meant Magura HS11/33, not the Magura disk brakes. Even still, it doesn't corrode the seals, it just doesn't lubricate them.
