brake cylinder washers
AlexClare94
echo tr brake clamps are designed to be used without any cylinder washers.
quote from tartybikes > "Unique design increases clamping force and removes the need for plastic cylinder washers, all you do is clamp your cylinders down and the brake pads are automatically set squarely! (Providing your frame/fork mounts are square.)"
the tr clamps are awesome, so much easier to set up without farting around with any cylinder washers!
you do have to take a file to the frame though and make sure the brake mounts are perfectly square and even, but this is a very quick and simple job and it only needs to be done once.
