Best Positions To Have My....
Ingram
Hi, Currently I have my speakers set like this....
Im aware they arnt in the best posbily place but i wanted to get them installed so i could hear them (Y) plus i thought it was the best places but people said to move the sub, so can people help me out a bit please, Whats the best place / position to place them, Cheers.
Im aware they arnt in the best posbily place but i wanted to get them installed so i could hear them :ermm: plus i thought it was the best places but people said to move the sub, so can people help me out a bit please, Whats the best place / position to place them, Cheers.
That looks ok?
Surround sound....It's Surrounding you?
Tom
I had mine like that, it worked well, then i moved my computer around so i had all 5 speakers facing me :ermm:, but someone trapped the cable in the door when we were having central heating replaced, so the "rear" speakers dont work any more :-.
Edited by *OnzaMike*
The positioning is fine, make sure, the front speakers are the same distance away from you, as with the rear. Rotate them, so if the sound was drawing a line through the air, lines would cross just in front of you for the front speakers and for the rear. Centre speaker directly under the tv, and your sorted!
Sub somewhere off to the side, out of the way, on the floor.
Andy
Edited by andyroo
Erm.are you taking the piss with that pic?! Look at the name of the file and the description.........
Rear speakers shouldnt "point" towards the user. They should be around 3ft behind them, 2ft higher than them, and be aimed across the room. Not aimed down or up or forwards. Just horizontal
No, it was the only pic i could find that indicates the correct positioning of the speakers around you to get the best surround effect. theres a decent pic in the sony catalogue, but i dont have a camera or anything. The speakers arent tipped back anyway, its perspective
And the height of the speakers wants to be when the tweeters are level with your ears.
And it means worst like 5.1 is the worst and 7.1 is the best
Edited by andyroo
