Wavey And Straight Rotors
matheprat
Are wavey and straight disc rotors interchangeable? I mean, to change from a straight rotor (to wavey) of a particular size, would you have to get a slightly smaller wavey rotor? As the bumbs on the wavey rotor would be larger than the diameter of the straight disc. Or doesn't it work like this?
Cheers
With wavey rotors you're supposed to get some tiny amount more braking power (something like 5%) and they cool down faster, which is a bit pointless for Trials where the rotor doesn't heat up much. They look cool though, especially the Aztec ones.
IMO straight rotors are better for trials, because you have more pad contact area with them which means better braking. All that wavy rotor does is puts air moving between pads and thus gives your brake better ventilation, but in trials you hardly ever brake from a big speeds.
For example, before when I had the wavy 180mm Louise FR rotor my brake wasn't very good and I was considering getting a hope trials front brake. But about a week ago I swapped my rotor with a mates 180mm straight Magura rotor, which was just hanging on his wall doing nothing(actually he had built a clock from it :) ). And when I had put it on, cleaned the pads and rotor and did a few stoppies down a hill, to bed the brake in again I was like holy shit, my brake has never been so good before! Ofcourse it can be different rotor materials or something, but I think that all magura rotors are the same material.
Edited by loffa
Im not sure Mr Leeson would agree with that, having not tested it though I have no idea if it works! See this
~Gareth
~Gareth
i wouldnt agree neither... as with a wavey disk, the pads will grip onto the edges of the disk and lock better. more pad contact off straight disks is usually better for modulation. the wavey disk will also help to clear glazing off your pads too.
this is simila to grinds on rims, it gives loads of little edges for the pad to grip on to.
This could be slightly wonky for a while as your pads will have been worn down from a normal rotor (or wavey) but if you change for the other then the pads will be worn down differently and may not work properly..
Much like filing a peice of metal...file one direction for a while then file another way and it feels odd then goes back to feeling and filing correctly...
If you understand me but it should feel ok eventually...or new pads...
