My Stubborn Magura
Krisboats
right basically my maggy keeps moving all the time
its the bloody quick realease side thats doing it, it keeps sliding upwards until the brake pad is rubbing on the tyre. i move it back then after bunnyhopping onto smething on my back wheel or even pedal hopping it moves to my tyre again. I've tried tightening it up and it worked a bit better but still did it.
shall i just put a fixed bolt in there and get rid of the quick release or just by a new egg timer bolt or something like that or will i just ned to clean it in some magic formula to stop it moving.
info that might help: its a 2004 magura hs33, with a standard magura steel booster, plazmatic pads, base ta26 frame, ground ronnie rim, and a better bolt in the bolt down side of the magura.
