Double Mavics
stevecoust
All the info you'll need here:
http://www.trials-forum.co.uk/forum/index....showtopic=63245
A couple of things to note is the width of the final rim, check your frame and pad combo can take it. Also the rims to use, as the X517 dented a lot - hence the reason I don't run mine any more! The weight as well is a large factor...
Mike.
