Help With Parts
trialsinchris
hi im thinking of getting a monty 221 pr frame in about a month for my birthday but i am using a headlock and i will need a new stem but the monty ones have sloped top caps i think? so which stem would be good to use that i could use the headlock with?
also i need a rear disc hub but dont have much to spend and cant really find any so im asking where they are available :(
any help appreciated
chris
Monty rear disk hubs are you best bet for a monty frame, theres the echo one, but that might be too wide.
What sort of bars are you using, as that affects the stem. If you have risers, then go for either a zoo stem, or echo stem. Flat bars, i would say a t-master stem, or again the echo.
