Bottom Bracket Q's
N Roach
Ite Dudes,
How long will the bottom bracket have to be if i'm going to run an saracen xile frame (Horizontal dropouts), with a Ultimate Hardware crankset 170mm long(22T), on single speed 22:18T ?
crankset 170mm long
[attachmentid=5206]
How do you work out how long the bb needs to be? :unsure:
Edited by chocolate_bikes
There is three sizes it could be 112, 118, 127 Now I have a 118 in my bike with three bb spacers, it should really have a 127 in it, so if you get a 118 be sure to get some spacers incase.
I am damn sure you can get a 121.5 as well.
Can you go into a bit more detail on the spacers, what the effect will be! (im only a beginner) (Y)
I think i have found a cheap 127.5mm bb http://tartybikes.co.uk/product.php?id=9 check it out or will the echo vp do a better job? http://tartybikes.co.uk/product.php?id=301
Will a KMC Z410 BMX chain fit my set up? http://tartybikes.co.uk/product.php?id=176
Get a shimano UN53 from wiggle.com
Cheap as chips, and everlasting too.
You can probably use a 112.5 or something like that, as exiles aren't exactly trialsy frames in terms of chainstay width, but if you want to be safe get 122.5 or something.
