Magura Problem
munch8987
Right
I've done a search and couldn't come up with anything
Basically what it is, i've done 2 fresh bleeds, had my local bike shop do 2 on my brake now and im still having problems. When i pull the leaver, bubbles and a small amount of oil squirts out of the slave cylinder, and this is out of the cylinder that doesn't protrude or retreat properly in the casnig
some-one please help as this is slightly :angry: gettig on my nerves!!!!
Any suggestions will be noted and will be made
Thanks for your help
Ben
Yor having alot of trouble with your maggy art you :S
Send it me if you like and i will sort it out for you (Y)
Upto you.
Yeah i am mate, just all happend at once, and it's just f****** me off now
Don't mean to sound horrible, but what can you do??
Fix the leak. Find out if one of your olives has a crack or something like that and needs replacing.
Does your turbo pad work?
I have had my brake blead with water for about a year and a half :S
As long as you bleed it regualr with water i cant see it ever causing a problem, no matter what anyone says about it corroding the seals :)
I would only charge you postage.
And whatever new materials you want. my ghess is it leaking out of one of these...
IPB Image
Where the red circle is, where the pipe connects, sometimes they get bashed, and pop or gradually over time it just seaps out of the bottom. ive had trouble with this in the past, and is easily fixed with a bit of new piping.
Where the blue cirvle is is where the olive goes in, sometimes they can crack or again in time needs replacing :) Sorry if im telling you things you already now :P , The same thing can happen with the pipe connects at the lever, this has happened at the lever a few times to me, as the pipe gets bacshed, the olive might move slightly, oil gradually seaps out.
Also make sure all you bolts are tight :-
There all the obvious places, if the oil is not coming ut of there please specify :)
cheers andy
EDIT: If you sent it me, i would obviously get to the bottom of whats the problem. then fix the problem.
I havent come accross a problem i havent been able to fix yet :)
I enjoy working with maguras. probably my faverite maintance bit on a bike B)
Edited by squince
IPB Image
cheers andy
WOW mate, you really must know what your on about, i understood most of the stuff you said...kinda...lol
If it's ok, i wouldnt mind sending it to you, so you can have a look
If possible, would you be able to bleed it with water, the more i hear good things bout it, the more i wanna try it :P
I have fiited a new Braided hosing to it, and it seems to be after this was fitted, my troubles started
Thanks for all your help
please PM me your address and ill sen it straight out (Y)
NOOO
Lose the braided :o
No wonder you have a spongy brake.
its horrible stuff IMO
Ohh S***, ok then
Umm.....in a word, no
haha :P
I can get the hosing for 7 quid including crossover.
And the olives for 1 pound each, then 3 pounds postage.
Paypal me 12 quid and send the brake to me.
You have my word your brake will feel stiff :)
Quick return (instant) :)
cheers andy
EDIT: send it to me on monday. i can get it back with you for wednesday :)
Edited by squince
haha :P
cheers andy
Actually.....just been through all my box of spares, and found a rear hose and cross over, couldnt have thrown them away. They just need the barbed pieces fitted again.
